Sunday drive ends with 000, I'm on fire.
Old 04-06-2014, 02:36 AM
o1xjr's Avatar
Received 6,327 Likes on 4,370 Posts
Exclamation Sunday drive ends with 000, I'm on fire.
Hi All, took the wife and nieghbours for a Sunday drive in the mountains today.
XJ6 caught fire on the way home.
No idea why but I took the fire extinguisher off the garage wall before we left and put it in the boot!. Got to be lucky some of the time
Attached Thumbnails Sunday drive ends with 000, I'm on fire.-dsc_8819.jpg   Sunday drive ends with 000, I'm on fire.-dsc_8825.jpg   Sunday drive ends with 000, I'm on fire.-dsc_8826.jpg   Sunday drive ends with 000, I'm on fire.-dsc_8829.jpg
314jjwalls (05-03-2017)
Old 04-06-2014, 02:52 AM
Received 4,454 Likes on 2,426 Posts
Bloody hell! What happened???
I take it everyone's ok?
The following 2 users liked this post by Cambo:
314jjwalls (05-03-2017), o1xjr (04-06-2014)
Old 04-06-2014, 03:46 AM
o1xjr's Avatar
Don't know, stopped at the lights and smoke bellowing from rear gaurds. Pulled up around the corner and had a look under,black melted plastic dripping from above right pipe where it goes up over the axle etc. Called Racq to get it towed but while we were waiting the smoke was getting worse so popped under for a gander and had a fireball ball happening up around top of suspension right near fuel tank . That's when the work place fire training kicked in and emptied the extinguisher into the fire then proceeded to call 000.
Got it in the garage at home now,was nearly dark by the time we got home so will investigate the cause tomorrow. Still no idea what it was. Right side of the car is sitting about 2" lower than the left now.
And yes everyone is ok,the girls a bit shaken. But they were sitting right above the fire
Old 04-06-2014, 04:32 AM
GGG is offline
Received 16,852 Likes on 12,186 Posts
Clarke,
I'm pleased to hear no one was injured and your quick thinking prevented the fire from spreading.
The fuel feed pipe from the side of the tank (item 20) to the pump is routed round the rear silencer. Here in the "Land of Rust", these would badly corrode posing a fire risk.
Even though rust isn't an issue in your country, the pipe or the rubber connections could have deteriorated over time.
The following 2 users liked this post by GGG:
Old 04-06-2014, 05:03 AM
o1xjr's Avatar
Default found 1 part on road.
Going to put it up on stands in the morning and have a good poke around to see if I can find the cause. If I can't find the cause or there is damage to shocks etc
I may put in an insurance claim . The brake peddle was getting a bit spongy at the last couple of lights I stopped at but I was putting that down to the very steep decent on a mountain road we had just done(20 km of downhill braking)
I found this on the road after car was put on tilt tray,I think it may be an upper mounting bush off a shock. Daylight will give some answers.
Attached Thumbnails Sunday drive ends with 000, I'm on fire.-dsc_8831.jpg   Sunday drive ends with 000, I'm on fire.-dsc_8832.jpg   Sunday drive ends with 000, I'm on fire.-dsc_8833.jpg
Old 04-06-2014, 05:40 AM
Received 6,307 Likes on 5,495 Posts
Glad your all OK, probably not the type of heated seats you would want to have.
o1xjr (04-06-2014)
Old 04-06-2014, 05:47 AM
Received 10,477 Likes on 6,918 Posts
BUGGA.
BBQ Jag is not nice at all.
That "bushing" does look like shocker related, and looks like "Nolathane" to me.
As Graham said, the fuel line TO the front is above the cradle, and the rear brake hose is just in front of the cradle also near the exhaust in a different way.
Still does not answer to me the cause of ignition??
An exhaust leak where the mount pin is welded to the thru cradle exhaust pipe could "blast" on that bushing, maybe.
The rear brakes have jammed and overheated everything, or the handbrake (well known issue) has jammed on, also overheating all and sundry.
The shocker bush more than likely answers the low stance I reckon.
Old 04-06-2014, 06:15 AM
o1xjr's Avatar
I did notice when I drove it into the garage the hand brake cannot be pulled on. But the car will roll when pushed in neutral.
Couldn't help myself,just had quick look under it with a torch. Looks like both discs and calipers have been really hot,maybe even pad material stuck to discs. Or it could be the powder from extinguisher. Not really enough room to get under tonight. But there is signs of melted stuff on both sides I think.
Grant Francis (04-06-2014)
Old 04-06-2014, 07:19 AM
Jose's Avatar
Received 2,443 Likes on 1,838 Posts
that's sad! all I can think of is a fuel line leaking and scraping against another metal part causing a spark and a fire. Hopefully there's no damage to any wiring?
o1xjr (04-06-2014)
Old 04-06-2014, 07:43 AM
mickvic's Avatar
Rear pads and discs metal on metal cause sparks or discs to get super hot, plus leaky fuel??
o1xjr (04-06-2014)
Old 04-06-2014, 08:15 AM
Wilfred88's Avatar
If your fuel would have caught fire, I think the damage would be worse right?
There can be lots of just grease and durt over there that caugth fire, because something got too hot. brakes? then a the undercoat also burns
(when I weld on the bottom, the undercoating always catches fire sooner or later. a little though, you can blow it out. But thats why I keep a bucket of water with me when I am welding. )
The following 2 users liked this post by Wilfred88:
level 1 (05-06-2017), o1xjr (04-06-2014)
Old 04-06-2014, 08:17 AM
Doug's Avatar
Received 10,872 Likes on 7,151 Posts
My money's on the rear brakes. Caliper sezied or dragging heavily, rotor gets extremely hot, piston seal melts, brake fluid leaks out and ignites.
Speculation on my part, of course, but I've heard of it before.
Of course, if you know the rear brakes were in good shape we can likely scratch them off the list.
The following 2 users liked this post by Doug:
Old 04-06-2014, 04:15 PM
Received 9,208 Likes on 5,386 Posts
Oh No!!
I hope it's not something disastrous, but easily repaired!
The following 2 users liked this post by LnrB:
Old 04-06-2014, 04:23 PM
o1xjr's Avatar
Rear rotors and pads were new 2000 miles ago, but a quick look points towards brakes. Putting it on jacks today to investigate. Hard to tell,a lot of powder up there from extinguisher.
Old 04-06-2014, 04:27 PM
o1xjr's Avatar
Insurance won't cover fire caused by mechanical, structural, or electrical failure.
What else would start a fire other than someone torching your car?
Old 04-06-2014, 05:43 PM
GGG is offline
The handbrake pads are tiny on the XJ's. If the assembly sticks on, they wear out very fast making metal to metal contact with the disc which then rockets the temperature up.
Old 04-06-2014, 11:20 PM
o1xjr's Avatar
Default Update
Been under for a good look,pretty ugly scene. Can't put a spanner to it until assessor has been, mechanic coming tonight to do a report on possible cause then assessor has to decide if it is covered by insurance. Until they make a decision I won't touch it.
It's looking like rear end removal though, pads decindergated,seals in calipers melted,pumps brake fliud onto floor,hand brake cable melted,rubber exhaust hangers gone, paint has burned. Lots of suspension bits melted. If insurer doesn't cover it I have a big job ahead of me. I was planning doing front end, but It looks rear end will be first now.
I will post some pics later.
Norri (04-07-2014)
Old 04-07-2014, 12:21 AM
red_101au's Avatar
holy **** mate,
never a good thing and as you say lucky for your workplace fire safety.
Glad no one was hurt but it is scary to think if you hadnt stopped and noticed it.... how far would it have spread while driving along....... end result could have been a hell of a lot more serious.
I wish you all the luck with the insurance company.... guessing it is not going to be cheap to fix it all...... then again if it works out too much they may just make it an economical write off.
Hope it all goes well anyway
keep us informed
o1xjr (04-07-2014)
Old 04-07-2014, 12:46 AM
Firstly, they are scenes enough to give any jag owner nightmares! two fifty liter fuel tanks, exhausts running next to them and inboard brakes are a good mix!
Ive heard that it was pretty common for xjs handbrakes to catch fire but i think that was because of the crappy lever design that would lead people to thinking they were off when they were still on.
Ide bet we are all on edge awaiting news on the next most important thing to check out on our cars!
Condolences old chap!
Jay
Old 04-07-2014, 01:09 AM
o1xjr's Avatar
Default Carry an extinguisher!!!
Hi Jay, the next most important thing you can check on your car is the extinguisher. Get down to your local Supercheap Auto store,they have them on sale this week for 20 bucks(cheap insurance). I just bought 3 this morning, 1 for the garage to replace the one I used yesterday,1 for the XJ6 and one for the wife's car. I always carry one in the Jeep mounted on the cargo barrier above the right rear passenger seat where I can open the back door and grab it, and one mountd each side of my camper trailer because this car is often off the beaten track. But have never really carried one in the town cars, new house rule from today.
Yesterday for some unknown reason I took the one off the garage wall and put in the boot when I was loading the picnic chairs and esky. Luck??? would have been no XJ6 if I had to wait the 7 minutes for the fire appliance to arrive.
I will post some pics of the damage on the Australia /NZ thread later tonight.
Update, spent so much time on the phone getting police incident report,fire service report etc, insurance co (3 departments) and so on. No time to take pics today
The following 2 users liked this post by o1xjr:
level 1 (05-06-2017), paulyling (08-15-2014)
Quick Reply: Sunday drive ends with 000, I'm on fire.
