Help with air con issue... Please!
2003 s-type 4.2L. (X202)
I am having issues with the air con warming up every time I stop at lights and the revs drop down. It have had the entire system checked and it is in perfect order, including the electrics. I found a TSB (JTB00183) that details a fix for this exact problem which involves a de-gas, removing a plate from the compressor and reversing the order of the valve and valve spring. In the TSB it states for the V6 only but I have been told that it also works on the 4.2L V8. Does anyone out there know if this is true? Cheers... Dave.
Grant Francis (12-05-2018)
I had the spring & valve switched around as per the TSB for my air conditioner compressor...Success!!! No longer blows warm air when stopped at lights and at idle temp is about 4 degrees C. The TSB says for the 3.0L engines only but my 4.2L has the same compressor and it works a treat...Cool driving
Received 3,242 Likes
Dave1963 (01-16-2019)
