LED headlights allowed in Vic
If you want to go this route I think its a matter of trying it and seeing if you start getting flashed for dazzling people. In the end it would come down to some coppers opinion ( I may be on the wrong wavelength here as you didnt say what beams you wanr to do , i assume both)
I recently updated the headlights in my car with higher performance low beams and added a light bar as the high beams were ok. I live regionally so need to be able to see the wildlife at night.
Thanks, I will check the federal requirements or just ask my mechanic. I checked the Vicroads requirement, and you are correct; all they have are additions rather than the actual headlights. Try it out and wait for others to flash in case it's too dazzling? So, what rating did you replace your low beam with? Thanks
