searching for 2007 Jaguar X Type Fuel Filler Neck
Old 01-28-2020 | 08:04 PM
tell's Avatar
Default searching for 2007 Jaguar X Type Fuel Filler Neck
Am hoping a member can point me in the direction of getting a 2007 Jaguar X type Fuel filler neck hose.
My local mechanic is fantastic and when i asked him why i had fuel leaking to the ground when filling the car with fuel, he took a look see and found the
problem was the filler neck. He has tried to source another one but we're not having any luck. Apparently Jaguar are no longer making them.
The mechanic said he might need to make his own, however i thought i would ask here first.
Would be very appreciative if someone could help me find a 2007 jaguar XType fuel filler neck hose pipe.
Suggestions are also most welcome.
Thank you.
Tell Johnson.
Old 01-29-2020 | 09:08 PM
dopey's Avatar
petrol or diesel
check out my thread on Jaguars at self serve wreckers there's a 2008 X-Type at Imlachs Springvale
Old 01-29-2020 | 11:15 PM
tell's Avatar
Thanks man, Calling you Dopey seems difficult for me.
Apparently getting at the filler neck pipe is not an easy job and also due to the age of the xtype the part might not be in fair condition, i say
all this as i parrot my mechanic. Unfortunately i have no clue about mechanics, i do know i really love this car. My lady has an xf and I prefer driving my xtype car. The steering wheel itself is a work of art and adds something special to the drive.
Mr Dopey, i dont suppose you're interested in retrieving the fuel filler neck and pipe from the Springy wreckers. Probably not and i do understand.
Even though most of the undercarriage of the xtype is ford, i think getting the part new will be impossible.
I do thank you for your suggestion.
Old 01-30-2020 | 12:43 AM
dopey's Avatar
sorry mate, not that I don't want to help, but you really need to check the part out to make sure it is correct and to your satisfaction. from what I can see the metal part should be quite durable
Old 01-30-2020 | 01:18 AM
tell's Avatar
Perfectly understand .
Thank you.
Old 01-31-2020 | 06:14 PM
dopey's Avatar
have you tried actually calling a dealer to see if the part is available? even if you can get the correct part number for you vehicle it will help narrow down the search.
there are a number of new filler necks advertised on ebay but you will need the part number to match.
Old 02-01-2020 | 02:40 PM
tell's Avatar
Default fuel filler piper
Part number is C2S49753. Ballarat Jaguar in Wendouree are a fantastic crew and were happy to give me the part number . They aslo
checked to see if it was still being made by jag, unfortunately it is not.
Thank you for your suggestion Dopey.
Prange
US Midwest
06-23-2018 10:25 AM
maxwdg
01-17-2013 08:24 AM
Greg Hamby
11-06-2011 07:19 PM
Real_Tech
General Tech Help
02-02-2010 08:57 PM
12-10-2006 03:03 AM
