Installed new tires/ balanced and aligned BUT NOW!
Installed new tires/ balanced and aligned… drove great first day but today at low speed car grunting /groaning with some noise from steering wheel ……cannot hear anything when at higher speed
Taking it back to shop tomorrow for sure! Anyone have any thoughts?
2002 X SERIES AUTO
2002 X SERIES AUTO
There are numerous things which could cause vibration/shudder.
Did you use the EXCACT size tire recommended by Jaguar? If not, check the wheel wells for marks, the tire could be rubbing.
Assuming that is not the problem, next time you get the car up to speed and get the vibration, put it in neutral and let it coast.....if the vibration goes away, the problem is in the powertrain.....if not, the problem is in the suspension/rolling stock and drive line. It is a process of elimination.
