s/s mesh front grill install
is this install as simple as it sounds? / requiring only a simple modification to the existing grille by removing the plastic bars from inside the frame. Full fitting instructions are provided.”
https://www.adamesh.co.uk/jaguar-x-t...sed-2465-p.asp
Achieve the eye-catching look of an Adameshgrill, but without replacing the surround. This lower-cost alternative of amesh insert is designed to fit perfectly into your existing grille surround.
Made in exactly the same way as for thecomplete grille unit, you are assured the identical high qualityelectro-polished, hand-woven stainless steel mesh which will not rust or chipand maintains a highly-reflective finish.
For a choice of style, the alternative of ablack-finish mesh is also available.
Suitable for all X Type Saloon and EstateModels up to 2008. It is easy to install, requiring only a simple modificationto the existing grille by removing the plastic bars from inside the frame. Fullfitting instructions are provided.
albert328gts
05-28-2012 11:07 AM
everlena
04-25-2010 07:24 AM
