Secondary Timing Chain Tensioners
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
2001 XKR Phoenix
30k KM
VIN SAJFA42BX1PA22744
have read lots of posts and Internet articles about this issue.
can someone give me some info as to whether or not I need to proceed with a preventive replacement of these troublemakers based on the vin and engine number I have posted.
much appreciated
30k KM
much appreciated
Check your driver door jamb placard. If your build date was July 2001 or earlier you have the old tensioners and need to upgrade.
If your build date was August 2001 or later, call your local Jaguar dealer with your VIN and get then to look up your engine number.
If you have an engine number of greater than 0108130000 then you have the new tensioners, if it is less, then you need to upgrade.
All this assuming you have an original engine in your car.
RoyLittle0
05-25-2023 02:38 AM
