Brake Dust vs Pinnacle Advanced Wheel Cleaner Concentrate
BEFORE
AFTER
The Brake Dust
Spray on Pinnacle Advanced Wheel Cleaner Concentrate
Color-changing formula dissolving ferrous brake-dust
Agitating wheel using a Speed Master Wheel Brush
Rinse thoroughly using Fire Hose Nozzle
And that's it! Simple Enough?
PinnacleWax.com
Fire Hose Nozzle
Received 9,011 Likes
Looks like a fantastic product, presumably acid free??
I was going to make my own short detailing post, but thought I would post it here as it seems relative.
On my X358 the upper and lower mesh grille are both chrome, the bottom one although shiny, on closer inspection is actually covered in dirt, grime such as exhaust fumes, oil residue etc etc that seems baked on.
I really wanted to clean this to a sharp shine, and as new if possible.
I used Sonax full effect wheel cleaner, a few simple sprays then agitated by a 1" paint brush, leave to dwell and then hosed off and it was simply as good as new.
The Sonax ( acid free ) seems to work similarly, in as much as it is applied clear then turns bright red as it liquifies the brake dust etc.
My assumption is that the Pinacle advanced cleaner concentrate would do the same job, can you please confirm, and do you have any videos to share?
Thank you
Thank you
......... On my X358 the upper and lower mesh grille are both chrome, the bottom one although shiny, on closer inspection is actually covered in dirt, grime such as exhaust fumes, oil residue etc etc that seems baked on.
I used Sonax full effect wheel cleaner, a few simple sprays then agitated by a 1" paint brush, leave to dwell and then hosed off and it was simply as good as new. .......
JimC64 (03-10-2014)
Thank you
Thank you
Like Sonax, Pinnacle Advanced Wheel Cleaner Concentrate is an Acid Free color changing cleaner. Pinnacle has several advantages though:
Similar
- Safe for ALL wheel finishes
- Color-changing formula dissolves embedded brake-dust particles
- Acid-free formula is safe for the environment
Different
- Concentrated formula dilute up to 1:3 with water
- Foaming action clings to the surface, increasing dwell time
JimC64 (03-11-2014)
JimC64 (03-11-2014)
Similar
Different
Similar
Different
- Concentrated formula – dilute up to 1:3 with water
Pinnacle - I have an idea .....lol
As I have been such an ardent fan of Sonax this past year or so, I bought 6 bottles last time as they are hard to find over here, and I believe the product is amazing.
The more I look at your Advanced wheel cleaner concentrate, the more I definitley see the similarities and I'm sure I could be persuaded on the additional pro's too.
I think you should send me a bottle to try against the Sonax I've used for years, a side by side comparision, then of course I can post the results
As I have bee nsuch an ardent fan of Sonax this past year or so, I bought 6 bottles last time as they are hard to find over here, and I believe the product is amazing.
Let me talk with my manager and it will have to wait until after this weekend. We are really busy getting ready for the Autogeek Detail Fest. But I'll let you know what we can do.
Also after this weekend, let me know when we can start setting up the next big Giveaway for Pinnacle Wheel products
Lol for sure, probably several, maybe even a video
Thanks Pinnacle..........as stated looking forward to the next big giveaway......I'm sure it'll be well subscribed as it was the last time!!
Shortly after the 29th, then we'll run with it for you and give it our FULL Attention
Hey Jim,
PinnacleWax (03-13-2014)
My Choice
Can't speak for the products listed above since I haven't used them. However, I have been using Mothers Wheel and Tire cleaner with excellent results over the years. The pic below is from my 1998 Mustang Saleen. I use the product often (each car wash) with no Ill effects what so ever.
KarimPA
09-03-2015 07:32 PM
