Engine Bonnet Insulation Cover
The insulation cover on the inside of the bonnet ('01 XKR Coupe w/86k miles) is dirty and needs to be cleaned and refreshed. I took a vacuum cleaner to the cover but did not improve the appearance. What do you recommend to clean this cover? Would steam work, like was recommended to clean seat belts?
For cleaning the BIC or hood liner, I would either go with the steam method or a light spraying of APC+ followed by a light blast with a pressure washer. Use a blower or compressed air to dry, being careful not to saturate the engine. Some of these liners when showing their age, can deteriorate easily and crumble...so inspect thoroughly before cleaning!!
By APC do you mean All Purpose Cleaner? What cleaner do you recommend?
Would you recommend a carpet cleaner followed by blowing the liner to dry?
I plan on trying this over the weekend and will report the results. The alternative is to purchase a new liner at $200, so I am motivated on the cleaning side.
David, I took your advice and ordered the Mequire's All Purpose Cleaner to use on the cover. Do you dilute this product? I read where other's have used it and used a ratio of 10:1. I'll read the product's instructions but was wondering what you would use to clean the cover after 86k miles. I plan on using the product on the interior carpets as well.
I show the car in the Jaguar Concours Championship class and have attended 4 shows this year with a final showing in Oct. The judges deducted a few points for this dirty cover, thus the inquiry. The car has averaged a score of 99.8 for the last 3 shows.
Hopefully at the next show, after this little project you will score a 100!!
Good luck!
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
KarimPA
09-12-2015 08:15 AM
KarimPA
09-03-2015 07:32 PM
