Glue removal
I would try......
No specific order, just get your arsenal together along with a chilled beverage of choice. If all of these suggestions fail, you may want to resort to a pneumatic tools with a prep pad like a body shop uses....
- Stoner's Tarminator or Xenit
- Meguiar's Body Solvent
- WD40 - see if it will soften up the glue
- Goo Gone
Car-Nut (04-13-2011)
Received 9,010 Likes
![Name: car01.jpg
Size: 19.3 KB](https://www.jaguarforums.com/forum/attachments/detailing-car-care-20/172932d1501289076-glue-removal-car01.jpg)
Autoglym Tar & Glue remover might be something to try?
Please see the link below.....
Autoglym - car cleaning products, car care products, car valeting, car detailing
For future ref-
3M Citrus Cleaner Adhesive Remover Spray -super powerful cleaner can be used to effectively remove grease, tar and adhesive residue and to clean and degrease metal parts, motors, tools, or use to clean the annoying residue from sticky labels. Aerosol spray can allows quick and easy application with a pleasant citrus smell
3M™ Adhesive Remover is a ready-to-use blend of safe petroleum solvents designed to remove adhesive deposits from exterior vehicle surfaces. To minimize the possibility of staining, do not apply in direct sunlight or onto a hot surface.Not for sale in California. Suggested replacement: 3M™ General Purpose Adhesive Cleaner
I haven't used that tar and gum remover. I have and do use goo be-gone. I have used it on clearcoat, leather and vinyl. You need to work very quickly with a tooth brush, and wipe up immediately. Use it in a spot where you can see if it changes the appearance before using it on a noticeable area. you may need to compound and buff, but the stuff gets anything off, including ink on leather and embedded pine sap. which is a real btch here in the northeast.
![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
I rate it as an 8\10 it was time consuming.
Hence this week-end I have my wifes nephew coming over to do my glue removal on the insides of my 4 doors.... A bit of cheap labour
Plus I can get on finnishing the irefit of my walnut dash ...
aholbro1
08-05-2021 05:02 AM
davidladewig
09-03-2015 06:32 PM
