Grease on My Carpet
I haved used with success the following products....
1) Stoner "Tarminator"
2) Stoner "Xenit"
3) Meguiars Body Solvent
4) Meguairs APC+
5) IPA
Start with the APC+ first, spray directly on the stain and using a MF towel try to wick up some of the grease. Apply some APC+ on the towel directly and rub over the stain....if necessary spray a little more on the stain then wipe. If you need a little more scrubbing power, use a clean toothbrush to help. If the stain still remains, spot clean using the Stoner product which is a bit stronger, then wipe dry. Then clean the area with APC+ one last time, wipe dry and you should be good to go......
2) Stoner "Xenit"
4) Meguairs APC+
5) IPA
JimC64
10-11-2015 09:04 PM
