Meguiars Ultimate compound Test/Review
First, just want to say I am a big fan of Meguiars products.
My wife's Lincoln MKZ was really needing a good paint correction and wax. Unfortunately with three other vehicles to keep up with the Lincoln was in need of a serious face lift. I tried some swirl remover in a test area and it just wasn't cutting it (no pun intended). Had a lot of light scratches and swirl marks a plenty so I knew compounding was needed. Have heard a lot of good things about Meguiars Ultimate Compound and for the price (under $20) I figured I would give it a try.
Used an Orange pad with my Porter Cable DA machine. I found it was pretty easy to work with and did not create a lot of dust. After doing a section I spritzed some water on it and wiped it off with a microfiber cloth. Easy enough.
How it worked: Honestly I expected more from the product. A good number of the light scratches and many of the swirl marks were still there. Were they better, Yes, but I really expected better results for the effort put in.
Would I use it/buy it again? Have to say no, there are much better products out there.
Think I'll stay with Wolfgangs products. I've used their Swirl remover and glaze and they're top notch. Think next time I have to tackle compounding again it will be with Wolfgangs Uber Compound.
Thanks for your recommendation. I was looking for a scratch remover and was reading this article, https://www.toolazine.com/best-way-t...inted-vehicle/ thinking to buy Turtle wax for under $20.
I've use it in the past to remove 1500grit sanding marks. For a consumer / retail grade product and it works as expected. The ultimate compound is not a professional grade product but its good enough for the DIY.
I did use a Rupes clone DA polisher with a 15mm throw which has abit more power than the Porter cable DA. I suppose it depends on the hardness of the paint.
I find Jaguar paint to be quite soft compare to BMW and Merc.
Terry007
Detailing / Car care
10-10-2017 07:50 AM
richzak
04-13-2014 11:56 AM
Thebeachatnight
05-21-2012 11:10 PM
