Pinnacle Crystal Clear Glass Kit
Everything you need to restore optical clarity – inside and out!
The Pinnacle Crystal Clear Glass Kit is the definitive answer to the problem that so many car care enthusiasts seek an answer to – and that’s how to achieve crystal clear glass, inside and out. Rest assured, the Pinnacle Crystal Clear Glass Kit includes the best glass cleaner, water spot remover and water repellent that money can buy – or else they wouldn’t have the Pinnacle name on them. Remove the water spots, mineral deposits and other contaminants that find their way to your vehicle’s interior and exterior glass surfaces and see clearly again with the Pinnacle Crystal Clear Glass Kit.
The Pinnacle Crystal Clear Glass Kit includes:
Pinnacle Crystal Clear Glass Cleaner with Water Repellent
Pinnacle Crystal Clear Glass Cleaner with Water Repellent is a spray-on glass cleaner that cuts through the toughest oily road film and grime to restore perfect optical clarity to your car’s glass windows. When oily road film builds-up on your car’s windshield it increases glare which causes vision safety issues and strains your eyes. Pinnacle Crystal Clear Glass Cleaner with Water Repellent easily cuts through oily road film, reducing night time eye-fatigue and making driving anytime safer and more enjoyable!
Pinnacle GlassWork Water Spot Remover
Normal glass cleaners are great for removing fingerprints, streaks and smears. However, a layer of oily road film or mineral deposits requires something more aggressive. Pinnacle GlassWork Water Spot Remover uses glass-safe abrasive technology plus a blend of citrus-based mineral dissolving agents to safely clean and remove road film and water spots off of glass. Pinnacle GlassWork Water Spot Remover restores a clean and crystal clear glass surface.
Pinnacle GlassCoat Window Sealant with Rain Repellent
Pinnacle GlassCoat Window Sealant with Rain Repellent is an easy to use advanced glass coating. It fills in all the microscopic pits, pores and other surface imperfections invisible to the un-aided eye. This creates a more perfectly smooth and hydrophobic surface, increasing your visibility and safety on the road. Once applied, Pinnacle GlassCoat Window Sealant with Rain Repellent repels water like no other. The surface tension created by this coating beads and repels water more effectively than you thought possible. Even in the most torrential rainstorms, the water beads up and flies off so effortlessly you many not need use the wipers!
Polish N’ Wax Applicator
The Polish N’ Wax is a triple layered foam pad with orange light cutting foam on one side and soft, gray finishing foam on the other side. The red layer in the middle gives the pad additional height so you can grip it without rubbing your fingers on the paint. The pad is oval for comfortable gripping, and it is larger than the average applicator pad so you cover more area in less time. The orange side is perfect for applying Pinnacle GlassWork Water Spot Remover as it provides the mechanical cutting ability necessary to engage the abrasives, removing water spots and other impurities from exterior glass.
3 Poly Foam Applicators
The foam wax applicators are perfect for applying Pinnacle GlassCoat Window Sealant with Rain Repellent. They minimize product absorption so you’re able to apply a thinner coat while using less product. When you’re finished, toss them in the washing machine and use them over and over again.
2 Waffle Weave Microfiber Glass Towels
The microfiber glass towel is bound to be a favorite. Similar to the popular Waffle-Weave Drying Towel, but with a slightly tweaked internal construction and a finer weave meant for cleaning rather than drying, this is the first waffle-weave glass towel. It’s soft and plush making it easier to clutch and control. Use this towel to buff off class cleaners or to remove glass polishes.
Kit includes:
32 oz. Pinnacle Crystal Clear Glass Cleaner with Water Repellent
16 oz. Pinnacle GlassWork Water Spot Remover
16 oz. Pinnacle GlassCoat Window Sealant with Rain Repellent
FS[NorthEast]: XJS 1995 Parting...Seats...Glass...sheet metal...
icsamerica
11-29-2015 05:25 PM
RaceDiagnostics
09-13-2015 02:22 AM
1964Daimler
09-09-2015 04:50 PM
