Pinnacle FLEX XC3401 Natural Brilliance Kit
![](http://ep.yimg.com/ca/I/pinnaclewax_2272_186129922)
The Pinnacle FLEX XC3401 Natural Brilliance Kit enhances the natural luster of your vehicle with Pinnacle’s naturally derived, scientifically enhanced products. The FLEX XC3401 Orbital Polisher helps your vehicle reach its shine potential by eliminating imperfections and restoring gloss. Find your vehicle’s true brilliance with the Pinnacle FLEX XC3401 Natural Brilliance Kit.
Pinnacle products combine the best that nature and modern surface science have to offer into simple and effective car care products. These concours quality formulas enable anyone to achieve a show-stealing shine on his or her vehicle using the basic principles of clean, polish, and protect. Pinnacle expands car care basics into a full car care system that results in a cleaner, shinier, slicker vehicle than you ever imagined. The Pinnacle FLEX XC3401 Natural Brilliance Kit gives you the tools and products to achieve your vehicle’s own natural brilliance.
The Pinnacle FLEX XC3401 Natural Brilliance Kit includes:
FLEX XC3401 VRG Orbital Polisher
The orbital rotation of the FLEX Polisher simulates the circular movement of the human hand while polishing. This motion is less likely to cause holograms than a rotary buffer. At the same time, the polisher's highly smooth running facilitates a careful, precise finish and allows for hologram-free polishing. The positive drive ensures a uniform movement, even under load, thanks to constant lift. Taken in conjunction with the large stroke length the FLEX can remove existing holograms from black finishes. The large stroke length refers to the size of the orbit. On many dual action polishers, this is a very small distance and therefore you feel a jiggling motion. On the FLEX polisher, the stroke length is 8 mm, a huge distance in terms of orbital polishers! The FLEX Dual-Action Polisher has a true dual action motion that reduces vibration. The FLEX Orbital Polisher’s smooth acceleration and uniform, controlled motion make this DA machine ideal for novices and pros alike. The FLEX XC3401 dual action polisher comes with a 5.5 Inch Hook & Loop Backing Plate and a 1 year manufacturer warranty.
16 oz. Pinnacle Advanced Swirl Remover
Pinnacle Advanced Swirl Remover brings “user-friendly” to a whole new level! Diminishing abrasives and water-based lubricants blend away imperfections gradually, leaving a smooth paint surface. This tempered approach to polishing eliminates imperfections while being extremely gentle on the paint. Pinnacle’s diminishing abrasives are tempered to break down slowly and evenly under the motion of the oscillating pad. A dual action polisher provides just the right motion and friction to maximize the performance and working time of these abrasives. This approach softens the abrasives’ impact on the paint, which ultimately preserves more of the paint. If you have a newer vehicle or meticulously maintained paint, Pinnacle Advanced Swirl Remover is for you.
16 oz. Pinnacle Advanced Finishing Polish
Pinnacle Advanced Finishing Polish gives your vehicle’s paint maximum impact with a clear, reflective gloss and flawless appearance. This is more than a finishing polish; it’s the final word on shiny, smooth paint. With micro fine diminishing abrasives, Pinnacle Advanced Finishing Polish burnishes paint to a crystal clear gloss that looks and feels mirror-smooth. This is our most user-friendly, clearest-finishing final polish ever!
16 oz. Pinnacle Liquid Souveran Wax
Pinnacle Liquid Souveran Wax is the only liquid carnauba wax to come close to the sizzling shine of Pinnacle Souveran Carnauba Paste Wax. With an amazing blend of carnauba and liquid crystalline polymers, Pinnacle Liquid Souveran Wax achieves the deep, wet gloss of a paste wax in a long-lasting, easy-to-apply, liquid formula. The polymers are added to enhance the brilliant shine, the protection, and the durability of Liquid Souveran.
16 oz. Pinnacle Crystal Mist Carnauba Detail Spray
Natural carnauba wax gives Crystal Mist Carnauba Detail Spray its distinctive, wet-looking shine. Carnauba, combined with crystalline polymers, creates sharp reflections and silky paint. This state-of-the-art carnauba-polymer matrix also enables Crystal Mist to bond to the existing wax for an instant but long-lasting gloss. On top of Liquid Souveran™ Wax, Crystal Mist reactivates the existing wax so you’re not just seeing a surface gloss – you’re seeing the depth and dimension of multiple layers of carnauba.
Detailer's Tip: Mist the foam pad with Crystal Mist prior to applying a polish or wax. The damp pad will spread the product more easily than a dry pad.
1 CCS 6.5 Inch Orange Light Cutting Pad
Firm, high density foam for scratch and defect removal. Use this pad with polishes and swirl removers. It’s an all around pad that will work on most light to moderate imperfections. Apply Pinnacle Advanced Swirl Remover with the orange light cutting pad.
1 CCS 6.5 Inch White Polishing Pad
High absorption foam formula for the application of waxes, micro-fine polishes and sealants. This pad has very light cutting power so its perfect for pre-wax cleaners or the application of Pinnacle Advanced Finishing Polish.
1 CCS 6.5 Inch Blue Finessing Pad
This blue foam pad has soft composition for applying glaze, finishing polish, sealants, and liquid waxes. The soft pad has no cut, making it perfect for applying nonabrasive products evenly. Apply Pinnacle Liquid Souveran™ Wax with this pad.
2 Gold Plush Jr. Microfiber Towels, 16 x 16 inches
The Gold Plush Jr. Microfiber Towel is made of incredibly soft and plush microfiber in a handy 16 x 16 inch size. It's perfect for quick detailing and pampers every surface it touches. The Gold Plush Jr. Microfiber Towel measures 16 x 16 inches and features an outstanding 70/30 blend of polyester and polyamide. The microfiber’s weight is 380 g/m², making one very soft, thick towel! It's perfect for buffing.
See our Dual Action Polishing Guide for more information on polishing with an orbital or DA polisher.
JimC64 (02-25-2014)
mikiep
12-20-2019 07:37 PM
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
