Snow Foam & Convertible Top
For the first time the other day I used snow foam. In fact, it would be fair to say I ended up using rather a lot of snow foam. This was entirely unintentional. Being new to the art of detailed car cleanliness I over-egged the amount of concentrate in the lance attachment. The driveway, garage doors and one small brick wall are now very clean too!
However, I do have a serious question for those in the know. I deliberately avoided spraying the convertible roof, but inevitably some landed on there. I had reproofed the fabric only a week ago so the beading is still good. I rinsed off the excess foam from the roof quite quickly, but wonder if foam has any adverse effects on roof fabric - anyone know?
Haha, I love snow foam too.
If you used a ph neutral snow foam, then it is absolutely fine to use on roof fabric. It's no different to carwash, and it shouldn't cause you any issue. The only time it will affect the proofing on the fabric is if the car wash has some sort of stripper in it, like CT18 truckwash.
Do you know what snow foam mixture you used? We can have a look to see how ph neutral it is.
Thanks.
I used Autobrite Direct Magifoam: MagiFoam - The Ultimate Pre Wash Foam
As far as I can make out it's reasonably harmless!
