whats the best glass cleaner?
I highly recommend Meguiar's D12001 Ammonia Free Glass Cleaner......Its a 10:1 mix so this one gallon will make 10 gallons. Works awesome under any conditions.
Description:
Ammonia free glass cleaner
Packaging:
1 Gallon, part # D-12001
5 Gallon, part # D-12005
Features:
Paintable:
Yes
Dilution:
(Water : Glass Cleaner)
10:1
Application:
Dilute. Spray or wipe on, wipe off.
Hazard Rating:
Health = 2 Scale: 4 = Extreme Fire = 3 3 = High Reactivity = 0 2 = Moderate Specific Hazard = 0 1 = Slight
0 = Insignificant Warning: FLAMMABLE. Liquid may burn with invisible flame. Causes eye and skin irritation. Moderate inhalation and skin absorption hazard. Harmful if swallowed.
Description:
Packaging:
Features:
- Non-ammoniated
- Non-butyl
- Non-streaking
- Biodegradable
Paintable:
Yes
Dilution:
10:1
Application:
Hazard Rating:
I have used Spray Way for years on all my vehicles including several MBs and on my XJR. It is inexpensive, ammonia free, and leaves no films or streaks. I started using it when I worked in new car make ready at a dealer and it has always been a dependable product, Now if I can just keep my wax from being discontinued by the maker ....
![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
I'll admit to being a low-tech kinda guy, but someone showed me a simple method a long time ago. It's always worked great for me.
Plain water with a touch of white vinegar added. Wipe off with wadded newspaper ... something about the newsprint or ink does the trick.
If nothing else, it's cheap to try!
Good luck.
Good luck.
guy (11-30-2023)
Received 9,009 Likes
Received 10,876 Likes
I'll be trying some of the above products/suggestions.
My problem, which I welcome comment on, is "out gassing" from the interior plastics and vinyls which leaves a rather oily-ish haze on the glass over a period of time. it is difficult to remove. It just smears.
Anyone else have this problem?
I've seen that on my trucks windows because the dash they use is of such high quality (insert sarcasm here). I know exactly what you mean but it seems odd that a Jag would have the out gassing. For interios cleaning I usually use Stoner glass cleaner and or Adams, both of which has removed it from the trucks windows. If it stays oily, it's likely a case of repetitive cleaning until it's removed.
Thanks.
I've also wondered if perhaps the cleaning/conditioning products I use?
I use Aero 303 on plastic/vinyl and Leatherique and Lexol on leather...but none of them are used excessively, IMHO.
Good luck.
Good luck.
What’s a newspaper?
blackenedindustries
09-30-2015 10:17 AM
vacolorito
09-25-2015 09:29 AM
