EGR help and thermostat coolant housing leak
Hi all please bear with me fairly new to all of this, going to clean my EGR tomorrow done a pre reccy over the EGR and it looks like a blanking plate has been installed, if the EGR needs cleaned is it worthwhile putting the blanking plate back in? if i don't does it need a seal instead (where the blanking plate was). i have also discovered i have a coolant leak from the thermostat housing (common problem i believe) underside of the housing is wet and a lot of liquid has gathered on the engine bay underneath to the right the coolant level has dropped to just under the min. i need to top this up any recommendations on what brand i should use oh and how easy is it to replace the housing unit.
any help would be greatly appreciated.
cheers
steve
cheers
steve
