Smoky
I was following my car home tonight and it was blowing out more black smoke than I would have thought it should do. It was only when accelerating and briefly as if at the times the car's auto was changing gear. It was recently serviced and MOT'd and there was no issues. It does tend to do short journeys, but about 2 weeks ago did 220 miles twice in three days on the motorway, so it has had a good run.
It is not a DPF version, the tail pipes point down. Is this something I should investigate further?
Received 1,236 Likes
its quite simple;
if you are using standard diesel fuel, when on high load conditions(like acceleration or steep hills) it has to make some smoke,
tests have shown diesel combustion process, makes PEAK torque occurs at PEAK smoke conditons!
but we cant drive around in those conditions, people would complain,and right fully so.
so fuel mapping is done to reduce smoke and also reduces power.
and so a lot of potential power is left unused for the sake of peace! LOL
plus our newer engines are designed less robust,because we under fuel them.
hope this helps, i do wonder what would happen if we could really raise the mapping in ECU, to find the integrity limits of a 2.7L Jag diesel car.
reasearch costs money, wouldnt be great to have a 4.2L V8 twin turb. engine, with 6spd twin clutch trans
Delta66 (04-28-2011)
Vector
US Lower Atlantic
04-11-2015 09:39 AM
