Hi, Does any one know where the fuel pump module is on a diesel e pace 4wd 2018? Mines broke down and the fuel pump has been replaced but still no joy. I've seen on other threads that there is a fuel pump controller/ module. I've looked under the rear seat near the pump but I can't find it. Or does anyone have an electrical diagram of the fuel pump system? Any help would be greatly appreciated.
I saw you had realised your mistake and reposted this question here. I've deleted the other version from F-Pace forum.
The module is part of the fuel pump. Here's the relevant E-Pace diagram from the Parts Catalogue:
Jaguar frequently repeat designs across models and it looks similar to the F-Pace. Here's the description of the module from the F-Pace Workshop Manual:
A different shape tank but a very similar pump and module.
Just an update on my e pace. Had to bite the bullet and pay jaguar well over £500 to change the fuel pump module as they wouldn't tell me where it was located until after they had fixed it.
Well here it is to save anyone else a fortune. You can buy this from loads of places or on eBay from around £40.
It is located under the left wheel arch cover.
Remove the wheel, remove wheel arch cover (or bend it back) then swap the module. Two screws and a plug. Simple.
If that's how jaguar treat their customers well that's the last jaguar car I'll be buying. Because they couldn't fit me in I've had no car for 6 weeks. If they'd told me where it was I would have fixed it on day 1
