1970 series 2 won't start
At the end of 2018, while car started right away, the little red ignition light on the dash bd was staying on. After several uses, I have to turn key several time to get the car cooking. Now wont start at all. I knew it wasn't the battery but I replaced it anyway ( as it was very old). Any suggestions to what I should be looking at or where? Any help will really be appreciated.. Thanks Rich
Do you mean the engine will not fire or that it does not turn over? If the latter, the little red light is telling you that the alternator, regulator or wiring has failed and your battery is dead. A service manual will show you how to short the regulator to determine which component is the cause. If the former, Alfred had some good suggestions.
hillskier
02-11-2017 08:16 AM
paul-hb
08-14-2013 11:35 AM
srdat
11-22-2009 05:44 PM
