69 e-type no blinkers
I believe the flasher is behind your instrument cluster, in the fuse box area....Should be pretty obvious when you look in there....
Before you do that, try turning your hazard flasher switch on and off a few times,(rapidly), and see if that brings the turn signals back....
Also, make sure you are using the correct # bulbs...Flashers work on resistance, (heat), and a low resistance bulb , will not allow the flasher to work.
Edward
Edward
owgcars5353 (07-29-2015)
It worked. New issue.
Thanks Edward. Not sure why, but both blinkers working fine. Took it for a ride and unfortunately another issue came up. When its a warm day and I travel 15-20 miles, it acts like its running out of gas. It spits, sputters and pops. If I let it sit for a moment, it will again start but will only idle. try and give it gas and it dies. If I let it sit for an hour or so it will go. I tried tapping the fuel pump with a screwdriver to no avail. I'm planning on starting with replacing the fuel pump. Any other suggestions? Many thanks for your time. Rick
That's a strange coincidence...Had the identical issue yesterday, on a long ride.....
My first thought is bad gas....I use 93 octane non-ethenol, from the same station, but wondering if I got the bottom of the tank stuff....I had to nurse it home, but when I got above 60, it smoothed out a little. Going to take a look at the pump, also.
Edward
Edward
Jaguar Forums Editor
Jaguar Press release
09-24-2015 11:08 AM
