73 S3 V12 Won't Start
List:
I replaced my fuel pump, filters, and added an inline filter before the fuel pump just for safety. I believe the fuel starvation issue is now fixed. I have oodles of fuel coming out of the hose right before the carbs. For some reason, the car has decided not to start. Checked fuel and there is plenty. I removed a spark plug and checked for spark and - no spark. I drove it in the garage prior to replacing the fuel pump. Hadnt touched anything in the engine bay, had the battery ground off while doing the pump job.
The engine turns over just fine, plenty of battery juice and starter power. It has a nearly new SNG Barrett electronic igntion setup. Any ideas what to check? I checked connections on clips and plug wires at all places.
Thanks in advance,
Jim
Thanks in advance,
Jim
Also is the timing right ?
I think so. I had been testing the coil and removing and reinstalling connectors and it now runs. However, after driving it, it is acting like it is fuel starved and popping. Not sure if something happened to the electronic ignition or the fuel pressure is low. Have a fuel pressure gauge on order to test. Thanks ,jim
