Acceleration Issue
I have a 73 E Type S3 2+2 V12 auto. 52k orig miles and was working great. I drove it around the block after redoing the front brakes and all of the sudden it started hesitating when I hit the gas pedal. I can pump the pedal to the floor in drive while driving and it doesnt really do anything. it doesnt feel like a miss, but something much more. I was able to idle home carefully back to the garage. It idles in park perfectly and accelerates normally when you pump the gas. However, when in drive under load, it is not working and i cant get the rpms up.
I have an SNG Barrett electronic distributer kit installed. That was done by previous owner last year. It was running great so not sure what to check.
Thanks,
Jim
Thanks,
Jim
Received 10,872 Likes
I agree, check fuel. For years I had an acceleration issue, the engine would stumble an falter. I ruled out ignition etc. As it turned out with mods, headers, air cleaners, ignition, had put a strain on the carb needles (Triple SUs). I switched to a slightly richer UE needle and the stumble cleared......
Good luck in your quest.....
