big valve v12
Received 1,236 Likes
i dont think Grp44 used all pre heads, i just junked 6 of them, i got $10. each.
also junked 3 V12 pre engines,got $75. for the lot.
junk is junk, until some one needs it.
grp 44 went thru a lot of engines because they are not that strong, after around 450hp they show the weak areas, but back then we didnt have a lot of experiance with V12 Jag.
for a perspective; the latest Nascar engines, use test specs, like 9500rpm, at full output, for at least 2hrs, steady, on the dyno.
try that in your spare time!
and using a marine engine for reference, is not realistic for road car, boat engines have an ocean of cool water before they overheat, unless someone does something silly.
