Brake Master Banjo Re-Alignment without Bleeding?
So I noticed while replacing my reaction valve due to the brake drag issue that my back banjo bolt alignment is causing the brake line to run on the steering shaft. I want to realign this and move it counter clockwise but didn’t know if cracking the banjo would let air in and result in needing to bleed the system. Any advise or help is much appreciated.
paddyx350
08-05-2023 02:18 PM
TommyBoah
19
05-02-2021 08:49 PM
