Condensation in Distributor Cap
Just took off my distributor cap to try and find an intermittent issue I’m experiencing with the ignition cutting out on occasion and discovered a build up of oily type of condensation on the underside of the cap. Just wondering what may be causing this and what I may be able to do to stop it from happening?
I’m currently running a Crane Fireball XR3000 ignition system.
Cheers;
Cheers;
Hmm 🤔,
This particular cap doesn’t have a vent hole. Had 2 previous, so called Lucas caps bought new, and both developed hair line cracks within 6m thus failing.
Bought this one without the vent hole and it’s lasted a few years now, but the condensation is building up. Also noted that this cap doesn’t have a gasket to seal it against the distributor body.
