Distributor issue!! Help much appreciated
So I just had my 1969 e type running but not running correctly. It was drivable but at a 2.5k idle. So before I continued on with setting the timing and tuning the carbs I replaced and gapped spark plugs, replaced spark plug wires, dizzy cap and points inside the dizzy also a new condenser and brand new coil. Now since replacing everything I can not get the darn thing to start! I have the Hanes repair manual and although the ipb for the dizzy internals is terrible I am pretty sure I put everything in correctly. Please where do I start? Any very common mistakes when rebuilding these? I also put a screw driver in the lead coming off the coil and there is no spark. Maybe a better repair/troubleshoot reference than the Hanes manual? Any input very much appreciated and thank you in advance.
This may be a dumb comment but remember on the E type #1 cylinder is closest to the firewall which is kinda backwards compared to other British cars. Check the plug wires.
If it's trying to start and backfiring the timing could be way out. Set #1 cylinder on the compression stroke and check the static timing.
Ol Blue (12-07-2015)
What you're describing is consistent with poor ignition timing. If the points you replaced were badly eroded, or the gap was profoundly incorrect, the ignition timing could be altered sufficiently to make the engine difficult to start when replacing the points. Ensure that you have the correct points gap now that the new set of points installed. As you were going to the trouble of replacing the points, I would have replaced the points system with an "In Distributor" electronic ignition system. It is visually undetectable, and you can say good-by to having to set points ever again. In fact, even though you have the new points installed, you should consider replacing them with the electronic system, as they are not all that expensive. There are quite a few manufacturers of this type of device, Pertronix is one that springs to mind.
I would suggest completing a Static Ignition Timing (ignition timing with the engine stopped) before you try anything else. You should find information in you Workshop Manual as to the angle to set for Static Ignition Timing. Once you have done this, the engine should start and the Dynamic Timing checked with a Strobe Timing Light.
This is quite a basic mistake, but ensure that you have all the plug leads connected in the correct firing order. I work a lot on V12 engines, and its not all that hard to connect a couple of leads up wrong with the V12 configuration. On the 6 cylinder engines, number 1 cylinder is closest to the firewall.
Sorry andypreston for the reiteration of what you said, I was still typing when you made your Post.
Regards,
Brent
Thanks guys will keep in mind. I did set the wires up correctly with cylinder 1 being closest to the firewall. Actually it was kind of a no brainier because the wires were pre-cut to length. With my distributer as far as the gap goes I think I am confused. It seems no matter how I adjust the base plate via the adjustment screw the point always go back to touching so how do I proper set the gap. The Hanes manual is very vague.
Hello Ol Blue,
Regards,
Brent
Regards,
Brent
Is this what you are referring to?
Yes, that's the Pertronix's device.
With the In Distributor, Electronic Ignition System (irrespective of brand), the signal is derived from a Hall Effect Sensor. Accordingly, the gap between the magnets (6 magnets (for a 6 cylinder engine), located equidistant around a ring that is secured to the distributor centre shaft), and the pickup sensor is unimportant so long as the sensor is not touching the ring. Correspondingly, there is no requirement to use a feeler gauge to set any gaps.
Regards,
Brent
Ol Blue (12-08-2015)
XXCalibar
11-17-2015 12:03 PM
