Fast Idle - '74 XKE V12
You have a leak somewhere. IIRC there are no fewer than 17 vacuum taps from the 4 intake manifolds and they all go to various T's and connections that can leak. If you haven't replaced all the 40 year old vacuum tubing then you should do that first. How about your gulp valve, is it working properly? Your carbs also have throttle bypass valves that let air pass around the butterflies under high vacuum conditions. If those 40 year old diaphragms haven't been replaced then that would be the second place I would look.
XKE73EIconverter
09-26-2015 10:21 AM
