Finally sorted out, 123 distributor and Cool Cat radiator/fans made it happen!
Many thanks to all who who contributed their thoughts and suggestions on my 69 Es ignition (dead Pertronix) and cooling issues (OE radiator finally gave it up). Hopefully the last pieces went in this week with the install of the beautiful piece of aluminum art called a radiator, along with the upgraded fans and Mike Frank's suggestion of thermostat. Car is tuned and running great with the 123, and now back to his indicated operating temperature in the O-R range on the temp gauge. I appreciate all who took their time to share recommendations and experiences. It made it that much easier to decide how to go forward. THANK YOU!
I just went with the base unit. While I do a lot of my own work on the car, adjusting distributors is not in my skillset... too many other settings depend on that distributor, so would prefer to leave it to someone who knows way more than I. I did buy the coil and wires that were recommended to go along with it.
Dibby.. I will research the procedure you described for adjusting the curve, so that I'm sure I understand the steps.. What is the expected difference in how the car runs? Does the timing need to be reset after changing the curve? Yes, I did buy the 123 for XK engines.
Bill, will take some photos. It is the XK-E manual transmission radiator and dual fans from CoolCat. I also put in one of the Thermostats that Mike Frank recommended ( link is on the CoolCat site). Took the old boy out for a quick spin this afternoon. Fully warmed up, temp gauge needle still on the O-R on the gauge. An expensive project, but IMO worth the peace of mind
Here is a link to a picture of a 123 showing the steel cap. It is just to the left of where the wires exit the body. Your cap may be red or black, but the steel cap is still there. You can see the Allan key hex shape in the cap. https://www.google.com/imgres?imgurl...MygGegUIARDiAQ
You may be able to have yours recored. 25 years ago, I did that and got 25 years of temp gauge readings in the O-R range. It wasn't until this past spring (2021) that trouble began. I don't concours my car, or show it much, but I do drive it. Didn't want to worry about that needle over at the right side, IMO, dangerously close to red. Not sure what JCNA judging says, but I'll stick with this new one.
I did consider having the radiator recored but... I have a recored radiator in the roadster and I am not happy with it. Could just have been a bad job. Anyway, I am not planning on showing the car, and I am doing several upgrades to improve drivability like a 5 speed gear box. So, I am not opposed to installing some more modern/improved components. Just don't want to over do it. All the upgrades I am doing to the car can easily be brought back to stock.
Bill.
Bill.
https://www.coolcatcorp.com/Merchant...tegory_Code=CS
No modifications needed. Plug n play, not plug n pray.. Check out the Coolcat site. Mike Frank will answer all your questions promptly. There are probably cheaper alternatives, but I am done with going the inexpensive route and then having to pay again for not having made the right choice the first time. A radiator that was over 50 years old and already recored once had done its duty. Time to move on.
enderle (10-18-2021)
[QUOTE=Valerie Stabenow;2453151]Many thanks to all who who contributed their thoughts and suggestions on my 69 Es ignition (dead Pertronix) and cooling issues (OE radiator finally gave it up).
Small world, My Pertronix unit crapped out after 4 years, just got a 123, and I switched to a Cool cat rad three years ago.
Cheers, Alfred
Cheers, Alfred
