Fuel pump config
I just took some pictures of the fuel pump area in my 70 OTS. Maybe these will help.
https://goo.gl/photos/3x9pVR52uizrMe929
https://goo.gl/photos/ySy8VXdrBwVE1Yyp7
https://goo.gl/photos/mrqKv3SUPdzKUQks6
https://goo.gl/photos/skGGBL2LBcUWbsHN8
Good luck,
Jim
Good luck,
Jim
I suggest you look here for the definitive answer. Page 42 gives the exact placement for your S2 pump.
http://sngbarratt.net/catalogue/etyp...%20Low-Res.pdf
Fuel pump config
Thank you for the help it has been most beneficial. My car had an after market pump ( not an SU or like) which was connected to the body with one bolt and no pump mounts, I am assuming that the pump is connected to an "L" bracket by a clip and the "L" bracket connected to the body as is shown on xk's diagram.
