Fuse panel won’t fold forward
Panel
Year and model always helps us help you.
that said, have you been able to lower it in the past? If so,, how long ago? Was there any work done in that area that might contribute to the problem?
here's a link that may help
https://forums.jag-lovers.com/t/e-ty...a-s1-car/99456
My 67 OTS has the same exact problem. It is the radio frame. Mine has been reupholstered and the material is slightly thicker than the original, causing a much tighter fit that doesn’t allow the fuse panel to rotate properly. You must remove the radio frame in order to access the fuses. There is a rubber seal at the base of the panel you may choose not to fold that in, this way there a little more room to open the panel. It worked in mine making it a little less challenging
You are exactly right. It was the radio frame. My car was recently reupholstered as well.
Thanks so much for all the help.
Dan219 (12-13-2023)
