Good car ramps for DIY E-Type servicing?
Hi all ! I am new here, just posted my new E Type in the Introduction forum. I'm now wondering if anyone here has developed a good system for using car ramps to raise the car at all four corners, as a servicing option to jacking the car up using the methods I have been reading here on the forums. Without building an entire drive-up set of rails, has anyone done a system where you drive up on front ramps, with flat jackable/scissor lifts under the rear tires? Or maybe drive up on forward ramps, then use a floor jack to bring the rear up onto jack stands? Thanks!
There's a lifting ramp system called Quick Jack. Basically a set of rails that you drive over then jack the whole assembly up. It locks in place maybe 18 inches high. Kind of like a motorcycle lift. I've only seen it in magazines. I've seen another type that uses a set of rails that you drove on, then jack up.
I am going to replace the transmission in my XJS soon. My plan is to use a pair of ramps under the front wheels, and maybe another set under the rear. Even with a few jackstands under there for insurance, there should be plenty of room to move around. I bought a new low profile floor jack from Harbor Freight and it works great. I'm thinking I might just buy another one, then I can jack both right and left sides at the same time. Then put the ramps under at the same time. Those four post lifts would be great if you had the money and the space, but I really don't find myself working directly under the middle of the car too often. (Except when working on the transmission!) Usually I will be working on a "corner" of the car, removing the wheel to work on the brakes, suspension etc. I just changed out the lower control arms on my Mustang, not fun. I've got suspension work to do on both the XJS and XJ6, Anyhow I will try to document my "struggle" on my blog and post a link.
I am considering getting two drive-up ramps, then creating/welding a piece of diamond plate to go under the rear wheels, with a cross-bar in between that can be jacked up. kind of like a mini-version of the rear part of the second photo I originally showed up above. I want the solution to be small. Otherwise, I'll just use my two floor jacks and four jack stands. If it isn't small and simple, I might as well install a two-post lift.
Here is the link. The guy is out of Cambridge, UK. I loved his idea and design, but these are a tad bulky for what I want. But I want to basically do the back half of this idea. For a quick two-wheel lift.
Car lift/ramps - the simple unique patented MR1s for DIY mechanics
plums (01-25-2017)
I never drove my XJ6 onto my ramps as I was nervous about driving off the ends ! You need quite a bit of throttle to get the car to move up and it just made me nervous. So I used to jack the car up then drop it down onto the ramps. Of course if you have four you just do the first two and then jack up the rear and drop onto the second two.
Once I took delivery of the car this last week, I jacked my car up using a wooden block I created - it has a groove that fits the block up nicely onto the forward sub-frame crossbar for secure jacking. The floor jack had plenty of room to spare, so my initial concerns about difficulty with a floor jack were unwarranted. Looks like I'll just jack the car, and place the jack stands under the suspension-to-frame points.
