Help with detail/polishing metal under bonnet
Hi, new owner of an old 1963 roadster here. The car is in good shape, but I am starting the daunting task of detailing under the bonnet.
First question: I removed one of the Su Carb's dash pots, and tried to polish it. Nothing. Tried Brasso, Maguire's metal polish, even toothpaste along with one of their rim polishing ***** as recommended somewhere. What finish is on these things, nickel plating? Or are they aluminum like the valve covers? Do I just need to get them refinished, or am I using the wrong materials?
(they look better in the pictures than in person)
Thanks!
Thanks!
Hi MyJaguarDream,
The carb dash pots are aluminum, like the cam covers. They shouldn't be plated or chromed. Some people use one of the Mothers powerball with your favorite aluminum polish. The final step is to use a micro fibre cloth and baby power or talcum power to bring the shine out and remove the black polishing residue.
After watching quite a few You Tube videos, I now realize that my aluminum parts just need a more aggressive polishing. Almost 60 years of use will do that it seems. I ordered a bench top polishing motor, a few cloth wheels, different grades of polishing compounds, as well as a whole set of incremental
grade sandpaper for my orbital sander. I also have a 3 year old stainless steel exhaust system that I hope to polish up, and since I have a month or so with not much to do, it seems like a wise choice. I'll post some after pics when I'm done.
I thought you all might like to see how the polishing is coming along. So I sanded the Carb bells with 220, 320, 400, 600, and 800, followed by Polishing with Tripoli and White Rouge. It took quite a lot of time, but that's the one thing I seem to have a lot of. Obviously, I still have a lot to do.
Brian
help with detail/polishing
Looking so much more brilliant after your hard elbow grease. Word of caution...be sure when you send your pots out for refurbishing that you make note of their original order...front/center/back...so you can return them to their proper position. Be aware that they were originally specifically machined to precisely fit each individual carburetor. Usually you'll find someone has dimpled them with some sort of identifying mark. Note too that over aggressive polishing generates a lot of heat which can easily warp dash pots and valve covers.
