keys
key photo(s)
And I forgot to mention , if you would like photos of the key 'heads', I can post those.
Here is a link to a fairly well-known British parts supplier, generally, IIRC, accessories:
https://triple-c.com/Jaguar_Replacement_Car_Keys.cfm
the ignition key for the Series 3 looks alot different than my Series 2, but not sure if anything was changed for the glovebox, and all my reference books remain silent.
case42so (11-13-2022)
sticky
I had REALLY good luck this past month with my stiff right side door hinge. I tried WD, teflon lubricant, then bought a fresh can of PB blaster... That nailed it. see if you can get that little red pipe in the lock opening, then also spray some on the key itself and insert it and work it. If you can isolate the handle from the body.. a hair dryer might warm it up a bit, too.
oldGwichkid008 (11-27-2023)
