New tires for 73 e type Roadster
Although the actual tire dimensions vary between manufacturers, the theoretical increase in rolling circumference between a 205/70/15 and a 225/70/15 is 88mm (3.46in).
Regards,
Brent
Received 10,871 Likes
Correct Doug. When installing tubeless tires on a tube rim, must use tubes. Coker Tire has both tube and tubeless. If you want radials, they will come as tubeless and you must mount with tubes. Coker Tire has an ask us on website and you will get an answer in 24 hrs. Verdstien tires come both ways too.
Make sure that all labeling is removed from the inside of the tubeless tire, when using a tube....In addition, the inside of the tire must be clean , and free from any roughness or debris...It takes very little to puncture the tube, when it rubs against the inside of the tubeless tire.
Finally, a little talcum/baby powder inside the tire, will reduce friction on the tube.
Edward
Edward
With the restoration on my 74 E-type almost completed, I am looking for replacement tires. Based on what I have gathered, the replacement should be Dunlop Acquajet 205/70/15's. I have not been able to locate a supplier in Ontario, Canada for this brand of Dunlop. Anyone have any suggestions?
stanjag
08-30-2015 10:35 AM
