Oil pump priming
Oil pump priming
My jag has sat unstarted for about 3 years or so. I just changed the oil on it in preparation to start it. One of my friends mentioned I may need to prime the oil pump to avoid damage to the shafts and whatever else since it’s been sitting. Is this necessary? If so, how do I go about doing that?
Your neighbor is obv. a Chevy man. Those could be primed but the best you can do is remove your spark plugs which will reduce stress and turn your engine over until you have pressure registered. XK engines and the V12 (not sure what you have) are very robust and it is doubtful any damage would be done if you do not prime. Assumption is the oil level is correct and filter is sealed. Good luck!
etypefancierjr (07-15-2022)
Oil pump priming.
In case anyone was curious, I pulled the plugs, cranked until I had oil pressure (which also means I got the oil filter sealed correctly, a feat I wasn’t positive I had accomplished) and it seemed to work just fine. Got the car started up not long afterwords so this advice seemed to work just fine! Thanks!
mattfirevai
XJ XJ12 ( X305 )
23
09-26-2020 07:56 AM
benters
03-19-2020 09:03 AM
