Paint Stripper Recommendations
paint stripper
I stripped my 69 using aircraft stripper. Be sure to protect the floor with heavy duty sheet plastic and change out of whatever shoes you are wearing while doing the work. If you mistakenly get the stripper on your shoes, it will eat house flooring. Using a heat lamp on the area/section that you are working on helps to speed the process. Be sure to wear protective breathing and eyewear. Read and follow the manufacturer's directions and precautions. Dispose of used material safely. Don't keep used cloths, paper, etc that has stripper on it indoors. Put refuse in a fire/flameproof container outside.
