pull tranny without removing v12??
one year almost to the day- blown head gasket- pulled engine and everything else from the engine bay- had heads done- all gaskets,seals bottom and top replaced- frame, firewall and every component cleaned up and refinished- transmission got torn down by local shop and necessary components replaced- all back together and with a bit of professional assistance, got it started
you never know till the test drive- engine purrs!!- unfortunately, tranny pops out of third when i lift off the gas- the repair shop has been notified
so the $64,000 question- i know whats involved in pulling the engine-been there- has anybody ever been able to drop the transmission with the v12 in place?
thanks guys
thanks guys
yep but it's fun. need to pull out console . move a/c unit over to the right. drive shaft,crossmember,part of exhaust. 71 2+2 has a few rubber plugs in floor to get to top bolts..but if you've pulled engine before then you've already found out how to get to top bolts...did mine in a weekend for a flywheel.
anyway, moving the ac aint much compared with pulling the v12, eh
let me know what you think- thx- chris
aholbro1
08-05-2021 05:02 AM
