re opus ignition
re opus ignition
I replaced my ignition with the SNG Barrett reopus ignition system for almost a $1,000.00 to eliminate the heat soak problem. The car runs great until I turn it off and let is stand for about 10 minutes. It will not start. There is no voltage to the coil. I let it sit for about an hour and it runs starts and runs fine. It's like someone turns a switch off. I hate paying good money for a fix that does not fix. I hate doing the same job over and over again. Anyone got any ideas about the SNG Barrett reaps problem?
Voltage to the coil comes from the ballast resistor which gets it from the ign switch.
You can check voltage into the resistor at batt voltage and voltage out should be around 10 volts. It could be a faulty resistor or just high resistance in the wiring.
The fuel pump gets its power from the ignition switch. Is the fuel pump running when you have the No start condition?
hot starting problem
DavidJC
08-16-2018 08:41 AM
Jag-o-nomic
03-29-2016 07:35 AM
