Rear control arms
These are well known for this. When I replaced mine, I covered the area with anti-seize.
Good Luck....
Let us know it that technique works for you...I ended up having to cut them off with a "Wiz-wheel"...(very carefully!)...After drilling the rubber all around, and dropping away the arm, leaving the cup still attached...One good cut in the cup, then whacked it off with a cold chisel.
Edward
Edward
JimC64
31
04-23-2016 05:32 PM
