Rear Wheel Bearing Hub
I'm Trying to Remove the rear wheel bearing hub to gain access for u-joint inspection I am under the impression that the hub slides off once the center nut is removed what is the torque spec on the nut upon reassembly. My Second Question is I am replacing the clutch and I was wondering if the engine can be removed without removing the manual transmission
Thank You Jag902
Thank You Jag902
innzane
09-02-2015 10:08 AM
