Refurbish or Purchase Front Brake Calipers?
My dad has a 1964 E-type Series One 3.8.
His question is this:
"Is it advisable to refurbish the original front brake calipers or should I purchase the larger calipers? I am told that the larger calipers, when braking is applied, there is a moment of hesitation before the calipers grab the rotors, which to some drivers is very annoying."
I tried refurbishing the front brake calipers on my 68 E type. Had them resleeved and pinned. Never quite worked well, (leaked) so replaced them with oem. type calipers from XK's Unlimited. All worked well with the replacements. For a stock not used for racing E type oem. cylinder replacements should be fine.
Dad's Jag (11-06-2014)
Larger calipers, that is, calipers with larger diameter pistons, only in the front, will change the brake bias toward the front, and increase the amount of travel of the brake pedal before the brakes take effect. It will also give slightly more braking with the same amount of pedal pressure. Your choice.
I would not be afraid to rebuild the calipers you have. You probably need new pistons and a seal kit, clean all the rust out with a wire wheel on a Dremel tool and you should be successful. The rust rarely makes it past the piston seal, the bores are usually OK.
Dad's Jag (11-10-2014)
Can you post a link to where you found the stainless steel cylinders? Might be interested when replacing my rear cylinders.
SNG Barratt - The Ultimate Jaguar Parts Specialist
A bit spendy at $208 each, but they should last for most of this century, plus you get 10% off by quoting JaguarForums.
The following 2 users liked this post by SCMike:
gatekeeper (01-02-2015),
SNG Barratt USA (01-06-2015)
British parts northwest have them for $121 for rear and $178 for rear in stainless steel for the e-type
Jaguar E-Type Brake Parts From British Parts Northwest
Rick
Rick
gatekeeper (01-04-2015)
hunter34
19
09-14-2022 11:09 PM
philwarner
09-05-2015 10:05 AM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
