seat rollers xke series 11
We sell them complete if it helps?
www.sngbarratt.com/CatalogueProducts.aspx?m=11&c=585&s=17240&a=17253
Each slider should have four ***** (as in a ball bearing) to separate the two parts of the slider, and provide the sliding action with minimal friction. As it was the 80s, I can't remember the detail but essentially one uses grease to hold the ***** in place while assembling. The grease is an essential part of assembling the slides, anyway. There are a couple of split, or spring pins to hold the thing together when assembling.
Sorry I can't tell you more, it is too long ago, and memory fades. Did you not disassemble them yourself ?
The nylon little drums that are supposed to make the seats slide back and forth easy on an xke are self-undoing ! the nylon rollers/drums are a snug fit in between the seat slider tracks so any dirt or rust tends to make the seat more diffcult to slide Soooo
I removed the rollers and greased the slider tracks and they work like a charm without them ! You can hammer one track over the other to roll over the nylon drums to get them out.
Jose
12-18-2021 08:16 AM
FS[SouthEast]: S1 XKE OTS Left Tail-light
SCMike
09-22-2015 07:34 PM
