Series II Battery
For judging purposes, I would recommend your favorite garden variety 12V rectangular battery (preferably in black) that is sized correctly to fit the original hold-down bracket and cabling.
Received 10,871 Likes
I think the Jags of this period had Lucas-labeled batteries....which I'm pretty sure you can still buy. Even if the appearance isn't exactly the same as what was used in the 60s, it would be a nice touch, IMHO.
For judging purposes JCNA is very lenient, requiring only original configuration and that the battery fit properly in original holders. However, Optima batteries are specifically excluded....
From the JCNA Concours Rulebook:
“Fluted or cylindrical sided” (Gates-Optima type) batteries
are considered non-authentic."
Thanks Guys,
Very thoughtful guidance. They have these 'tar toppers' that are plastic shells which fit over Optimas. Kinda cheesey but are vintage looking. Is hard to switch out a 400$ New battery that is bullet proof came with the car. Lucas seems the best bet if one can find a black example with white lettering, but the ones sold out of the UK are flashy green!
This outfit (and surely others) should have something that looks fitting and proper
Antique Auto Battery
We supply a black rubber cased battery of the correct size if of interest..
We also have the battery decal available.
http://www.sngbarratt.com/ProductDet...9-b9b55226a696
SNG has the answer if really in the show phase. Can remove and use Optima for street. Only the rubber cases are not sealed and can cause corrosion from acid. Optima is a heavier battery. I found out when I used an Optima for daily and track, when it crapped out found the regular replacement was 5 lbs. lighter.
big k
10-29-2015 08:01 PM
big k
10-27-2015 09:09 AM
