Series II headliner Panel 2+2
A better solution, in my opinion, when the original headlining panel is non existent, or damaged to the extent that its tantamount to being non existent, is to use the headlining material supplied by BAS. This has a dense, but very flexible backing material approximately 5mm thick, with a wool lining. This material is glued directly to the inside surface of the turret. Its my understanding that its only available through BAS.
I've used this material a lot in my shop. The denseness of the backing material resists breed through of glue and circumvents hand and finger imprints through inadvertent excessive pressure during installation.
Regards,
Brent
