Shop time
SNG Barrat is my primary supplier for BIG panels and they use Martin Robey. Chuck at Monocoque metalworks is the feller for smaller panels and patch panels or one offs. A great ghuy to talk to and ask questions...he really enjoys the e-type and sharing his knowledge and skill through his panel beating. Check out his web site. A few small one/patches I do my self. Fitting is a careful dance of measuring and comparing sides. In the last e-type magazine a company is dissassembling a FHC and OTS and laser scanning panels to make super accurate panels...sounds promising!
SNG Barratt USA (01-11-2016)
Thanks for the reply...
Happy Trails....
Thanks, words of encouragement always appreciated. In the winter doldrums right now--too cold in shop. But spoke with my engine rebuilder and head is finally off. At first look is truly ugly but am having him proceed to attempt to rebuild all (head is worse) as it is a numbers matching car. I will post some phots
#31
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1124/20151116_201020_resized_1__34c8b7022dbd715be539bec1ab5db5ec7b41e893.jpg)
![](https://cimg2.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1124/20151116_201014_resized_95de2f39205fbbeef3321a235ab4e0935de1a12d.jpg)
This is a one owner low mileage car that sat in a barn for 35 years-Antifreeze turned to powder, took weeks of soaking to free head. Water passages don't look horribly corroded, but some rebuilding needed. Top of heads in cam valleys is nice and clean. Will resleeve if needed but will see. All numbers matching so worth the effort! Will post more pics as they come. Suppose to warm up this weekend so hopefully out on shop for some major body work--cutting out rear bulkhead as panel finally arrived and I fitted one sill.
#32
Finally warm enough to hold on to metal panel without getting frost bite. Spent about 5 hours in shop removing rear bulkhead, fitting new one (with clecos) and rebuilding left support for rear torsion bar. Some areas are remarkably free of rust while other areas are just gone!!. Thank goodness for the jig and being able to roll the body every which way on the rotisserie to each fabrication. Will post some pics of the fun
#36
#38
Yep, weld through primer for sure. I use to use bloxide but can not find brushable, only in spray and is very expensive in spray form. I will coat inside with red oxide primer before closing up the cavity. If Jaguar had used weld through primer these poor cars would be in a little bit better shape!!
#39
Between '96 and 2003, I did a frame-off resto of a early mustang cvt. I found much the same damage as you found here. Between the MIG, Plasma cutter and weld through primers, and the bare metal primers these days, I'm enjoying the fruits of my labor today. here, I have her in for new shoes and other brake work.
But looming on the side lines is my E-Type 2+2.
keep the work flowing........
