su fuel pump
su fuel pump
i am changing my fuel pump and finding that the replacements has very small o rings to seal the banjo fitting to the pump and fiber washers to seal the fitting to the bolt on the outside. the original has fiber washers on both sides of the fitting. I have cleaned the fitting surfaces and put it together several times, swapped the bolts and fittings and nothing I do seems to stop the seals from leaking. any suggestions??
thanks bill
thanks bill
thanks bill
thanks bill
Copper can work, but you have to "anneal" the copper washers, first...Use a propane torch, and heat the washer on a brick, or other insulating material....
Heat to red, and let it cool (don't quench it)...Once annealed, it will conform to the surface much better...
If you have to re-install the same washer, later, you will have to anneal it again.
Edward
Edward
prettygirl69 (05-15-2016)
mr barry, copper was one of my options. turned out after many hrs of screwing with it replacing the fiber washer between the fitting and the head of the banjo bolt with an o ring that fit snugly on the bolt and had a cros-sectional diam of 0.10 worked perfectly.
thanks for your suggestion.
back on the road again. bill m
Edward
Edward
For what reason are you suggesting not quenching the copper. A full anneal is achieved by quenching and obviously quicker than waiting to be able handle it using the fresh air cool method.
Regards,
Brent
Brent
Just from personal experience...Quenching seems to harden the metal, and may distort the shape....Time-wise, we are talking about two washers, may take an extra five minutes.
But whatever works for you is a good way to do it.
Bill
I'm not sure that the O ring is your best cure....While it may work for a while, the rubber will tend to twist under the head of the bolt, and might begin leaking sooner than you would like....
If it does, then you need to re-think the cure.
Edward
Bill
Edward
Brent
Bill
Edward
Bill
Edward
Pure copper can't be hardened by heating and quenching, irrespective of the quench method.
Alloys that harden during low-to-intermediate temperature treatments following solution quenching include precipitation hardening, spinodal-hardening and order-hardening types. Quench-hardening alloys comprise aluminum bronzes, nickel-aluminum bronzes, and a few copper-zinc alloys.
None of the above named alloys have the typical appearance of copper. Copper washers are generally pure copper.
Regards,
Brent
that is interesting because unlike the old pump the new pump came with an o ring seal on the pump inlet and outlet face. I will watch it closely.
does anyone know of a source for soft copper washers with the i.d. o.d. or do I have to grind one out of the typical copper washers made for oil pan and tranny plugs.
bty I really appreciate all the input. bill
The o-rings that came with the new pump, are they rectangular cross section or round? Just curious. Or maybe a washer with an o-ring bonded inside?
su fuel pump sealing
mr. barry that could be the correct spelling for the man welsh pointed me toward if he rebuilds su's and strombergs at a shop in ny.
the o ring that came with the new pumps is round in cross section.
I have also found crush copper washers that will fit the outside of the banjo fitting/bolt at partsklassik.com. they mainly sell Porsche parts and were very helpful. they appear to be a good resource.
bill
bill
jagxkrtoofast
06-11-2011 07:51 AM
