Tachometer issues
I guess nobody understands how this system works. The ignition system matters, and the tachnometer needs to be adjusted. On a '69, it's an easy task, because the tachometer can be adjusted without opening the case. There is a trimmer that can be accessed by an opening on the back of the case. It will covered by a rubber plug or if it's been adjusted before, by a piece of tape. Just pry it open and you will be able to reach the trimmer with an insulated screwdriver. Start the car and adjust to match any good shop tach.
