Throttle doesn’t return to idle
![](https://cimg4.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/694x400/xke_throttle_linkage_ipc_f349c462e5bb6ca52f066cf363641162783c8adb.jpg)
If you have twin ZS carbs, with Auto transmission, then this is linkage that needs to be Isolated to find where the "stickiness" is.
Disconnect (item 12) at top to isolate FWD shaft from Firewall. if FWD then it could be (1) throttle plates in carbs or throttle plates in manifold.
(2) throttle cable (item 18)...disconnect the short link (no item number) at FWD location of Auto kickdown assembly. Cables do fail internally after many years.
(3) Loosen a clamp on throttle shaft between carbs, to see if either one is sticking. Each carb should return to idle with shaft clamp loose.
Lets us know if you need more specifics.
Rgds
David
The Coupe
03-28-2012 08:00 PM
