Valve adjusting shims
Making my way through the engine rebuild of my 66 OTS. I am in need of some shims and I thought I would ask about in the forum before buying new. Would anyone want to swap some shims via post. I am in the Houston area so if you are around here.
I have a batch but one never has all the right sizes.
Ok, so no takers on your offer. Actually a very good idea too!
Many years ago when faced with the same issue, I soon learned one needed a bunch of different sizes available to get the proper clearance. Since I did not want to buy a boat load of different sizes (expensive back in the day), then, pick through them and return the unused, I made my own.
I purchased cold rolled rod of a specified diameter. I sliced "wafers" from the rod, then, sanded to the correct thickness. After which, I heat treated the lot. That was 40K plus miles ago. I've owned my jag for nearly 50 years.
Good Luck and Happy Holidays
mbwillgrubs (12-24-2016)
I broke down and bought the shim kit from XKs, Costly, but I shimmed a MK7 in 3 hrs., and have plenty for my 2 MK 1s. A lot easier and quicker than running around and looking for the correct ones. Dealer, last time I asked ( 1975 ) wanted 8 hrs. + parts, with me bringing head to the shop. Did mine after ordering $25 worth of shims (1975) in 2 hrs.
